Howdy.
A few questions, if I may.
Its been about a week and ahalf and 500 miles later after my head gasket / engine rebuild. My nitrous system was in hibernation for about a year and 3 months. (never been used, tested, etc.)
When I sent off my head to APE, I had heavier springs installed, a resurface to the head, a port blend with valve job performed. I installed heavy duty studs and nuts when I pieced it all back together for the extra reassurance.
I'm running BoostBySmiths ECU flashing and all his electronic goodies for nitrous applications. i.e..switches, lockouts, etc. I've had the secondary (nitrous) map already tunned in and set before I blew the head gasket making about 205.9 hp.
Today I decided to TEST the system for functionality before I take it to get it reflashed and tuned again as I'm thinking my air to fuel ratio has changed with the port blend and performance valve job done to the head. <<Yes or No?
Anywho... I disconnected the line to my Gixxer plate and had wrapped the line to the outside of the bike when I took it out to test the system. My purge side of the system worked like a champ.. on/off/on/off..<all good. When I took it out for a ride to test all the "rules for engagement" of the nitrous system, I lost the rest of what was left in the bottle. It would appear that my nitrous side, possibly the solenoid? is stuck open?
My right pants leg was frosted over when I got off the bike as I was expecting just a couple bursts from the disconnected line. I know first hand how cold this stuff really is...
My triggers to the system is out of first gear, above and between 6k thru 10500 rpms, greater than 85% throttle and the starter button must be pressed. All of which are working as should.
If the solenoid is stuck open, how difficult is it to rebuild? < or is it even worth doing and just to buy anew?
Do I have the right idea as to getting the ECU reflashed after the head work or should the initial "stock" nitrous map be sufficient?
Is there a break in period on the "new" head that I need to follow before running the juice?
Really would'nt mind getting it retuned as I'm curious to see the new numbers with the head work done.. i.e... how many more ponnies did I gain, if any.
Thanks for any and all insight you have to offer.
Preciate Ya!
Preciate Ya!
