I have a dry shot and a Cycle tek air shifter. The shifter system kills ignition for about 50 milliseconds to allow the shift to happen (like most kill box's).
Question: can I spray nitrous while using the air shifter? It looks like it could theoretically be a problem since fuel and N20 would still be supplied for the split second that the ingnition is dead, allowing the unburnt fuel to accumulate and then backfire upon re-ignition. Or does it all happen so fast that it doesn't matter?
I'm probably just being paranoid - but thought I'd check with you guys.
