nitrous delivery question
mccama69
hello, i have a ZEX dry kit that i will install on my 05. can u please tell me which method of delivery is the best? twin nozzles in ram air tubes or spray plate that goes in bottom of air box where the diaphram used to be? i plan to start small but would like to work my way up to 60 shot. thanks
A Spraybar works the best. You lose 10-15% nitrous power when you plate the Nozzles in the Ramair tubes or a Nozzle plate
can i run a spraybar with an air filter? or can i just up the nos jet and fuel requirements to compensate for the 10-15% loss?
Use what you have and adjust the jet size. That will save you a little money for other mods. If you arent seriously drag racing your system will be fine.
i got the zex kit and had them send an extra line,T fitting and starter jets. also i bought the traction control box to control activation gear and rpm. i didnt know about the spray plate on the bottom of box at the time of purchase, it seems to be a simple solution over what i did. any other tips u could hook me up with? thanks
