Nitrous issue
McyMike
Put a MPS NOS system on my Busa last summer. Ran two bottles of juice through and it worked great. Took it to the track earlier this year and when I hit the "button" the bike would bog and fall flat on its face...thought maybe I had a leak and just air left in the bottle. Refilled the bottle and took it to the track last night...same problem. I can hear the "whoosh" going into the air box so I know somethin is making it there. One of the guys at the track said I may have pressure problems? Why? Worked good for the first to bottles under relatively same temperatures - why doesn't it work now???
Typically you want around 900-1100 pounds of pressure in your bottle,if you dont have a gauge I would suggest getting one becasue you can be a little more accuratethat way too,if you were say at 750lbs then that would cause ill efects on the running wich I beleive the lower the pressure the richer you will run and the higher the pressure the leaner it would run.As far as it falling on its face it could defintly be that you had too low of bottle pressure.If you can just pop off the airbox lid and make sure that you are spraying into the airbox good and go from there.
Just saw another thread ... same topic , different title
Still , check em then work your way back
