I've heard that a stock busa lower end will safely handle 220 or so at the rear wheel. A 40 shot on a stock busa would still be well under that.(busabbad @ Dec. 12 2006,17:57)
anytime you add more power to a motor, you add more stress to the parts.........will a 40 horse nitrous system hurt a busa motor if used in moderation?? looking at a zex dry system . what ya'll think........i will have 2 xtra bottles so refills will be alittle less frequent
Busas are proven to handle even up to a 60 dry shot safely. Now anything over that I would recommend a wet system. I'm running a 40 shot....(cougar694u @ Dec. 13 2006,05:47) A dry shot is a little more harsh than a wet shot. I'd drop it to a 25 on the dry, and 40 wet. My brother used some box to open the injectors to compensate so it appeared like a wet shot.
Maybe, but one small mishap and you've got a cracked/burned/melted piston. The wet shot is more forgiving.(BusaBusa00 @ Dec. 13 2006,11:42)Busas are proven to handle even up to a 60 dry shot safely. Now anything over that I would recommend a wet system. I'm running a 40 shot....(cougar694u @ Dec. 13 2006,05:47) A dry shot is a little more harsh than a wet shot. I'd drop it to a 25 on the dry, and 40 wet. My brother used some box to open the injectors to compensate so it appeared like a wet shot.
running boost the bottom end is good to low 300s.(johnnycrash @ Dec. 12 2006,06)I've heard that a stock busa lower end will safely handle 220 or so at the rear wheel.(busabbad @ Dec. 12 2006,17:57)
