Nitrous ?s
02badbusa
I have an 02 busa that is pretty much stock. I have just installed a schnitz racing dry kit with a progressive controller on it and had a few ?s about running the spray on a stock bike.
1st: what is the biggest shot I can run with out a power commander and with racing gas just for the spray. ( I will be getting one in a month or so )
2nd: I have .026 .034 .036 jets can you tell me what each is in HP with the super power shot noid.
I have run the .026 and it performed great and reduced my ET in the 1/8 by 3 tenths.
Thank You for your time
GREG
with the 2 dial,may as well leave it at 50 %,the nos solinoids won't pulse any slower
i wouldn't spray a busa with out some means of fuel enrichment,maybe a .016 or .018,but thats about it
bike setup,pipe,filter,map,will have a great influince on how much power the bike will make with each jet
.026 about 20 + or -
.034 high 30's to low 40's
.036 low to mid 40's
the numbers on a nitrous calculater look a lot more impressive
.026-30
.034-51
.036-57
well i sprayed my bike with a 40 shot @ 20% on my progressive without a pc,but you will be safer with a pc so you can add fuel.i ran 1/2 gallon 112 to a 1 gallon 93 with know detonation. but its like chevell said it all depends on your setup. my progressive comes in on wide open throttle,but if your on the start button 50% will be fine. it all depends on what gear you decide to hit it in.
Get one of these! It will allow you to run a much larger shot of NOS without hurting your engine. The Fast FI box will richen the fuel and let you run 50 plus HP jets without getting lean and detonating the engine. It doesn't replace a PC3 but it would be my next purchase if i were you.
I agree with you Sully, I also have the FastFI box with my setup...works awesome.....now if I can save a few pennies for the Progressive controller and Air shifter I will rule the streets......
