Nitrous System Mounted,,,Pic
gsp
whoa! Looks crazy! Dont laugh to hard on that stuff! Whats the red switch on the foot board for?
can you elaborate a bit on the mods you have done , turbo,nitrous v twin ? what kinda numbers are you puttin out lookin pretty nutz!
"Red switch"
Juice on........
stock 2053cc Kawasaki
custom PowerSports (Garret bushing type) T3 turbo @ .45 trim
stage 3 wicked wheel
Tial Waste Gate with boost control
running mild 6 psi spring right now
Greddy Blow Off Valve
PLX WideBand controller
PC3
Map sensor mod
600 cc injectors
pingel air
pingel billet forward controls
dry N2O with fuel map +fuel at 90-100% throttle
250mm rear on custom 18X8.5 wheel with 1.5" drive belt
135 lbs stripped from the factory bike
wind shield cut down to a small fairing
<!--EDIT|gsp
Reason for Edit: None given...|1134319240 -->
i was gonna say....that bike looked like nothing but GO from the first time i saw it! I'm sure your having fun! Keep the rubber side down!
Thanks,
I post here because of the good information yall have and the recommendations yall gave me for using Pingel air shifters..
Very good air system
horsepower/torque on and off the juice ? i was thinkin you had a few $$$$$$$$$$$$ tied up in there !
I make my own maps,,,, wideband control makes the difference and prevents BOOM!!!! I run 12:1 air fuel ratio
