I swear bikes are the most sensitive things in the world, it was a fuse but i SWEAR there was nothing blown last night at all. I changed the 10V fuse and we got light. Now on to the next small issues. Thanks fellas this site is truly a help.
I will check everything in the morning, my bike is basically ripped apart now looking for this freakin problem Will keep you guys posted just in case it isn;t the fuse. None of the fuses looked blown at all, but I will put the volt meter on them in the morning. Thanks again huge help.
just had this happen to me recently (Gen II) and it was a blown fuse. seems to be NOT the case with you.
Your fault description is very vague . . what the heck is a 'switchback'??Silly question. If you have no turn signal bulbs in...would that kill the gauges. Asking cause I attempted to install switchbacks and failed with the retrofit. When I plug the gauges in with the key switched on, they sweep the first time but that's it. No tail lights now either. So I'm hoping when the new switchbacks come in, it fixes this
Hello so where did u find fues at need some one helpHey fellas I checked the fuse box and all fuses are in tact. When I turn the key the headlight and fuel pump turn on but no other lights will work, where else should I look. Thanks
