Ken.Sutherland
Hi All, Hate to start with a prob but i need help. Wasd out on bike and it overheated and while riding all electrics died. It turns out i cooked my battery, have replaced and changed 2 fuses and now all looks ok except no prime. Turn on ignition and clocks flip as normal but engine temp max's out. Bike turns over but no start.
Its a gen2 2010, no hid, in fact removed headlight and sidelight bulbs to simplify.
The battery really got cooked and im concerned i have fried my ecu. Tested the ECT and sensor is showing expected 2.5k(ish), stripped right kill switch and verified all looks ok, not sure how i would do a wire check. I have removed the regulator and will be replacing it and a stator at same time, this is 2nd time a regrec went bad, my fault for bad diagnosis.
Suggestions?
Suggestions?
