Hello everyone. Good to be here. I come in search of knowledge. I have an '06 limited 15300 miles with clutch/slave issues. Slave extends and retracts when the clutch lever is pulled and the clutch rod is not sticking but if you're holding the lever and put the bike in gear it shuts off. I bled the slave and it didn't help. I'm thinking its a slave issue because even after bleeding the lever pull goes a bit soft again. Any other ideas?
