No lights or turn signals
Hawk14
Guys, I was installing my topgun undertails and stripping and wiring the tail lights when I allowed them to touch while checking to see that they were wired correctly. Well, after they touched, all the front pane lights went off.
The bike still turns on and runs, and I have head lights, but no instrument panel lights or functions, and no turn signals. I believe that this is a blown fuse that needs changing unless someone has another idea. I can't find my manual, so my question is where do I find the fuse for the turn siginals and instument panel so I can change it?
Sounds like a fuse YES. Left side top panel (to fuse block on left front under small plastic panel). You should be able to take the screw out and get at the panel.
