NOS in swing arm
badboysbailagnt
I know you can have swingarms made that has air tanks. But would it be possible to put nos in a swing arm. Im gearing up to race my buds gixxer 1000 and i want to hide the nos as best as possible. I also ordered the bracket to hide the air shifter as well. Im just going to tell the guy its extended other than that its stock lol
I doubt that a swingarm tank would hold enough pressure. You can get a sneaky pete bottle and hide that and the lines if you want, but it's a lot of work.
It would have to be a sneaky pete bottle, but why not just hide in the hump?
you can get a 1lb bottle that will fit under the tank ontop of the motor. won't need a bottle heater then either.
seen a couple local "hot shots" turnin their tanks on at the strip one night......
Schitz racing has a bracket that allows you to put a 2 lb bottle in your rear hump!!!!
<!--EDIT|GIXERHP
Reason for Edit: None given...|1128575555 -->
