not for small shots of nitrous ive seen 100 shot dry going on 2 years now with just a stock motor and a fast enricher no power commander and still goingstronger valve springs are needed.
wee
I want to get to around 230hp and still be good to ride the street. No specific quarter times, just want the engine to last as a stock one would. The budget i'm looking to do this is about 3 or 4 grand. i now have the brocks alien head, power commander, pingel electric shifter, 17 and 45 sprockets, lowered and stretched.NOS vs an engine build is a more complicated question than just the ti valves. What power do you want? Or what speed or 1/4 times are you looking for? Do you have a budget in mind? Nitrous can be added for less than $1000 for a wet system. I have had turbos, nitrous, stroker cranks, wet shots, dry shots etc so hopefully I can help some
A full engine build's labor alone will be over $1000. Give us some more info and we can help more.
Not on an 08 with titanium valves...not for small shots of nitrous ive seen 100 shot dry going on 2 years now with just a stock motor and a fast enricher no power commander and still goingstronger valve springs are needed.
wee
KWS motorsports has a ad in the 2 wheel tuner mag 240hp for 5k and when i called and told him i had the first step of three already complete he still told me i would have to pay five grand to get the job done. The first step was pipe and power commander. How is Lees performane?I have heard that a dry system is hard on a motor....Just had a buddy that blew his motor in is 07 GSXR 1K from using a DRY NOS system, and I believe it was only a 40 shot...
Putting a big bore kit in my 1K was about $6,100.00...You can check out lee's preformance or KWS motorsports for their engine packages. They do everything from just Cams, pipes and PC's to the full blown all out big bores....At least it'll give you an idea of a motor build and what you want...
Lee's preformance
KWS motorsports
what does titanium valves have anything to do with nitrous they have been running titanium valves in some of the biggest nitrous breathing cars foreverNot on an 08 with titanium valves...not for small shots of nitrous ive seen 100 shot dry going on 2 years now with just a stock motor and a fast enricher no power commander and still goingstronger valve springs are needed.
wee
Nitrous motors need plenty of valve spring pressure. This helps prevent mini backfires and misfires from throwing the valve down into the piston, disloging the keepers and putting nice little holes through the top of the pistons. I've run spring pressures as high as 75 lbs on N20 motors. Ti is strong, but very flexible and not very wear resistant. I don't believe they can run anything close to those spring pressures for any length of time. People do a lot of things that work for short periods of time.what does titanium valves have anything to do with nitrous they have been running titanium valves in some of the biggest nitrous breathing cars foreverNot on an 08 with titanium valves...not for small shots of nitrous ive seen 100 shot dry going on 2 years now with just a stock motor and a fast enricher no power commander and still goingstronger valve springs are needed.
wee
