Boosted Cycle Perf
As most of you guys know, a gen 2 Busa will make 230whp off a 4.5psi spring on 93 pump gas... well that is until you try tuning one on VP E98. I’m still blown away by this result.
So that is literally a bone stock motor? No spacer plate, turbo pistons, valves, retainers etc? I thought the gen 2 motors needed help to approach 300 hp?
Wow can you explain how? I know it’s alcohol but it’s not oxygenated. It must not take tons of fuel as running stock injectors.
Does a 4.5lb spring usually run 5.6lbs?
Same as e85. (85% ethanol) but it’s e98. 98% ethanol.50 whp from different fuel! Wow
Is VP E98 an ethonal fuel?
We don't have that in my area.
You got my number!I need to give you a call tomorrow Rob .
So you said the target afr remained the same correct? No timing adjustments? E85 or 98 has a different stoic value than gasoline. I don’t know crap about tuning bikes however I did the tuning on my TT Vette and for the Alcohol Vs Gas tunes the afr was vastly different as well as the timing. Please don’t misunderstand I am not questioning your ability, I am just trying to understand differences between the cars and bike.
I'm amazed at the results. I was under the impression that Gen 2's couldn't get much over 230 hp without engine work. I wonder what would the difference be on pump E85? I realize that stuff isn't consistent, but could it be tuned to safely compensate for variation in the fuel?
Would this be a better fuel to use compared to c16? For a built motor non intercooled set up. Or is c16 the best option to use for non intercooled.
That's an awesome guinea pig......For testing, as promised I picked up this little gem.
