NX flare jets converted to Flare
202mphbusa
can it be done?
I have a NX four fogger wet kit that uses Flare jets
that I am thinking would be far far easier to install with the 1/8 poly line that uses funnel jets
can they be converted? or will I have to buy four new nozzles?
Hi. You going to run nitrous with the turbo? This year I would like to get my 200 MPH ticket.
not sure I will run it
have zero need so far as I have at LEAST 20 pounds more boost I can throw at it before I even considering more power
BUT I have essentially three kits worth of Nitrous stuff sitting here
one is just a dry nozzle
the other two are NX promod kits with -3 an lines huge solenoids and what not
Come up to Loring, Bring helmet boots gloves and leathers the Hertz rent a A license bike can get 200 in fourth on low boost HAHAHAHA
Hi. I you want you can call me at 508-496-3312.
Are you using the fat stem flare jets or the skinny stem flare jets. They make a skinny stem flare jet that can be used in the same place as the funnel jet
can it be done?
Wait are you canning the reduce button for nitrous? :laugh:
Are you going to Arkansas or just Loring this year?
