nx xolenoid?
they make a flow checking device other than that I don't know if u could tell, if u don't think u r getting the right hit out of is ur bottle pressure right
Posted via Mobile Device
Good question! I'm only taking a stab at this...... I think about the only way to tell for sure would be to put (2) N2O psi gauges on noid(inless there's some kind of a "flow meter" made for this), one on the inlet side and one on outlet side. Turn bottle on read what the inlet psi is(800-900psi)then activate noid(**i would not do this with noid on or plumbed on bike**)and see what psi drop is? I cant tell you what psi drop should be, maybe call "NX" with data and see what they say, they probably could advise you of a BETTER WAY to check noid too? :beerchug:
