O2 Sensor
ctk0104
Banned
Hi I wish to check tat did anyone remove their O2 sensor? If u do remove it, what is e result? Good or Bad?
US models don't come with O2 sensors. I want to add one to mine. I think it would help me set my maps.
The 02 sensor is a major part of how your fuel management system reads how to meter the fuel delivery to the motor. If you remove it, you'll be effectivly blinding the computer and will probably make a (very) noticable, negative change in how your bike runs.
My winter mod list includes a pipe and http://www.bazzazperformance.com/ fuel managment system that includes an O2 sensor for self mapping on the go.
Answer.. don't remove it.
Hi, thanks for yr help for answering my queston. I have fix back my O2 sensor.
Hi all, I will be fitting a PC3 USB this weekend, I have an 02 sensor being a UK model. I have heard that in order for the PC to run properly it has to be disabled, either with a Dynojet eliminator or by pulling the pin in the ECM. Any thoughts?
Cheers, Matt.
O2 sensor 09 Busa
I just recently purchased a two brothers dual slip on system with juice box and it comes with O2 sensor block off plug. So I guess it won't matter because juice box is already pre programmed. And my exhaust where it comes into 4-2-2. Wondering if it will hurt if I cut exhaust off behind sensor.
