I noticed in looking at the various PCIII maps that the majority of the boxes, arranged in throttle opening/RPM range, have negative numbers, particularly in the middle areas. As these charts are called fuel tables, I take it the map leans the mixture (less fuel) in these throttle opening/RPM ranges. Replacing the exhaust with a free flowing high performance unit I would think would increase the amount of air going through the engine. Wouldn't more fuel (enrichening) then be necessary to maintain proper mixture? I realize I've made some assumptions here and I may be way off base.
