bauhaus15
Hello, new to the site, picked up a 2000 Busa to build and love as my own. I'm well on the way, until, the odd. I was changing the position of the rear suspension and that went without problems. Started the bike and rolled out of the garage. Outside in a sloped area (important? I don't know) bike would not start again. Pushed the bike back in the garage and again it would not start. No F1 codes (even in dealer mode). lifted the tank and looked around for the Oh... thats it, nothing disconnected, fuel pump not turning on. Checked the fuse and yes it was blown (should have looked there first I know), anyway started to blow fuses, I had recently changed handle bar position so I took the choke and the on/off switch apart to look for shorts (nothing), the clutch switch seems to be working since the bike is turning over same for the side stand switch. The bike turns over, fuel pump comes on then blows a fuse. I looked for a short, traced back to the battery and the ground seems hot, the ground wire is tight to the battery and the engine. I disconnect the coupling to the fuel pump and the bike fires up. Button the bike up after trying to start and restart. Roll the bike outside. Get things ready to ride and the bike will not start. It turns over and will not start, check the fuse and its ok. Pump comes no but bike will not start. Tank up, check the connection to the pump, work on the pins reconnect, bike starts. Fuse is ok, bike starts and restarts. Now I'm confused (ok more confused), I took a sample from my tank to see if I got bad gas. No seperation in the sample I took, but there is rust in the tank (I will drain the tank and have it coated), Now I'm thinking it is a fuel delivery problem since the bike will turn over but not start. If you have taken the time to read this I thank you in advance. I've been a rider of many bikes and wanted to get my hands on an unrestricted version of the Busa. The person prior to me did not love the bike, it is obvious, but with TLC I have the bike on dyno at 159 hp using an old version II powercommander. Oh, the bike was running and running well until I went to adjust ride height. It was set more for drag racing.
