Apocalypse
Does anyone have the OEM Grip heaters installed?
Are they worth it?
Are they worth it?
I'm pretty sure they're made by koso and I've found them on Amazon for 120 bucks versus whatever suzuki is trying to charge. I'm actually looking at ordering a set since one of my Oxford heated grips decided to go out on me shortly after I installed them . I definitely liked having heated grips on cooler nights so I'm hoping the koso hold up better especially since they don't have the extra controller piece that i didn't like with the Oxfords.Does anyone have the OEM Grip heaters installed?
Are they worth it?
They really do work!I don’t get grip heaters. The tops of the hands get cold not the palms. And in order to fully realize the effects of warm grips do you wear thin gloves? And with thin summer gloves won’t the tops of your hands get cold?
I tried them, but after 1 season ripped them back off. Found them too hard and vibeyI don’t get grip heaters. The tops of the hands get cold not the palms. And in order to fully realize the effects of warm grips do you wear thin gloves? And with thin summer gloves won’t the tops of your hands get cold?
I don't ride the Busa in cold weather, sort of defeats the purpose for me as I hate being wrapped up in tons of layers of gear. On the other hand, I ride the BMW in just about anything. I really like the heated grips. I don't like heated gear so much though as it feels drafty to me. I wear my heated gloves with no power over the heated grips. Keeping the top of your hand warm is mostly about wind exposure and the heated glove fixes that even off. I like just enough heat to keep my fingers from going numb. So even in the 5th or 6th hour of riding at 40 degrees F, it is comfortably warm. I rarely use the high setting as it is a bit toasty.I don’t get grip heaters. The tops of the hands get cold not the palms. And in order to fully realize the effects of warm grips do you wear thin gloves? And with thin summer gloves won’t the tops of your hands get cold?
Yes, thanks for that correction.In your last sentence you really meant heated grips not gloves right? My heated gloves that I seldom use are great cold weather gloves w/o turning them on. I doubt I’d even feel a heated grip with them or my usual cold weather gloves on.
