offset front sprocket ?
1320jon
I m wondering if anyone has a line on a front sprocket that is offset tothe outside .150 to .250. It appears that there is about .150 of splined output shaft past the oem sprocket. I don t want to just run a spacer, since I will probabably go past the available splines. I d like as much splined contact as possible. A 16 or 17 tooth is fine. Did suzuki make an ofset sprocket using the same splined output as the busa on a different bike? gsx1400...? gsxr 1000?
I could cut the center out of a stock sprocket.....jig it up , tig it together like a clutch mod, then surface it down as needed, but I d really like to get one as made in all one piece? Even if the offset is +.250 if I could surface it down as needed....
