You have a super charger or turbo? If so then your crank case can generate pressure and I would recommend a vent to atmosphere catch can. Besides that the amount of vapors released to atmosphere or intake is extremely low compared to a boost application. You won't see any added hp with this mod for NA as this is a massive topic already on the automobile threads.
Also if you do be careful on which catch can you use and the battle material used depending on fuel. Example, any catch cans with a spunge like baffle disintegrates with high ethanol fuels vs 10-100 micron metal baffles.
We also have 2 port injectors per cylinder to wash the intake valves clean of any carbon build up. The best thing is to always use top grade fuel like Chevron vs junk fuel like race track.
