Greetings,
Just did the oil/filter a while back. I removed the one end of the oil line from the oil cooler which allowed for easy access to the filter.
I ordered up some spare 90 cent gaskets from Suzuki with another order. You probably could use the old one but why chance it.
Coat the gasket with a little grease, use a little loctite and torque to 7 ft. lbs. (84 inch lbs.) Check for leaks.
hogger...
hogger...
