oil change
last year I put her up for 3 months and changed the oil/filter before and the oil after... I also would go out and start her and let her run until she was nice and warm.... did it help or harm don't know but I love the way she sounds and it help not being able to ride it
Maybe I am paranoid, but I do it before and after. I live in Michigan where it could stay in storage for 4-6 months.
If it's going to "Condensate" in the winter let it "Condensate" in the old oil.
Then change it before your first ride!
Just my .02 cents worth.......
Before and after here in Northern Vt.
Cheap motor insurance if you ask me.
Drain the old oil and put in the cheapest no name brand oil you can find. Leave the old filter on. Drain it in spring, replace the filter and fill it back up with your favorite synthetic. Filling the crankcase up to the filler hole is also a good idea as long as you don't forget and start the bike.
Starting the bike every week or two and letting it idle up to temperature is about the worse thing you can possibly do, it causes nothing but condensate and acid build up. You need to get out and ride it a good 10 to 20 miles.
it is in a heated garage, about 55 or more. any difference?
Short trips on any vehicle is hell on the engine, battery and exhaust system no matter what the ambient temperature. Idling is worse yet. If you don't want to put it in official storage you need to take it out once or twice a month and put some miles on it.
If you're not going to ride it, leave it be. Take the battery out and put it on a battery tender or a high frequency low amp charger once a month. Also get the bike on stands or move it a bit each week so that you don't ruin the tires due to flat spots.
never do it before dont see a need oil is not a sponge it doesnt soak up anything besides think about it the only thing staying wet is the bottem end so why it dont make sense kind of like wiping before you poop
So are you saying acids don't form therefore there's nothing to eat away at bearing surfaces or the coating on stator windings?
no ididnt say that but what does new or old oil have to do with it
what about cam surfaces in the top end that are essentially dry all winter?? it just dont make sense
the "point" is that you wash the surfaces with the fresh oil...and the acidic stuff that does sit in oil doesn't have time to cause any problems.
perhaps you should do a little reading...
http://www.totalmotorcycle.com/maintenance/motorcyclewinterstorage.htm
http://www.motorcyclecruiser.com/tech/winterstore/
http://www.clarity.net/~adam/winter-storage-content.html
http://www.maxmoto.co.uk/techtalk_winter_layup.shtml
http://www.amadirectlink.com/releases/winterize.asp
http://www.themotorbookstore.com/motorcycle-winter-storage.html
http://motorcycleinfo.calsci.com/StorageList.html
