Draco1340
There is a restrictor plug in back of the oil filter that helps route much of the oil (not all) through the oil cooler. I have removed the oil cooler and installed block off plates, but have heard different things on the restrictor. Should it be removed, or drilled out to a larger size. Otherwise the oiling system is stock.
