Warchild
Banned
From a different thread:
<div class="iF-Passage"><div class="QUOTEHEAD">Quote:[/Quote]<div class="QUOTE clearfix"><span class="quoteBegin"> </span>
that's why I had to remove the oil cooler line to remove the filter. Has anybody else with R-77 full system had any problems?[/quote]
You do NOT have to remove any cooling lines or anything else to remove the stock oil filter behind the Yosh R-77 4-2-1 headers.
HOWEVER....
That having been said, it is true that there appears to be even slightly less room behind the R-77 headers than the OEM equivalent. I did have to rotate the old filter around several times to find the correct orientation where it just barely slips right out of the area between cylinder #4 header and the oil cooling line.
And, of course, old oil is oozing out everywhere from the old filter as I spin it around like a Rubic's Cube while searching for the correct orientation....
Interestingly, aside from the initial 600-mile service, Suzuki calls for changing the oil filter every THIRD oil change! Normally, the Old School in me just won't allow an oil change without changing the filter too, however, between the ass-pain of the right fairing removal and having to wrestle the filter out behind the header pipes, I am inclined to follow a sightly modified Suzuki change interval recommendation, and do a filter change every *other* oil change.
HOWEVER....
