oil filter
Billy Busa
Banned
Im taking by 08 busa in next week for the 600 mile service.
The service guy said I should have a genuine suzuki oil filter instead of a fram oil filter.
Is there any reason for this or is it okay to install any kind of oil filter?
Fram=FAIL.
The stock Suzuki part rocks. It's built with a rock solid base-plate, it has a quality anti-drain back valve, and a bypass as well. The filter media is also high quality.
I would suggest sticking with stock. There are other quality filters out there, but Fram is not on the top of the list. It kind of defies logic, as they make a damned good automotive oil filter, and their air filters are high quality as well. Go figure.
Fram=FAIL.
Thanks
Stock is fine. There may be better filters out there but nothing wrong with the OEM.
--Wag--
Eliminate the guess work, just stick with the OEM. You'd be amazed on how many different models Suzuki uses just this one filter
16510-03G00-X07
why is it that Suzuki only has one spin-on filter and all the others have 4-5 different ones??
