Dr. Gonzo
Trying not to be a post ***** here... hopefully things will settle soon and will get some of these bugs worked out.
1. I noticed today that when I flip my 'tattle-tale' switch on the boost gauge that it doesn't hold the top boost mark for long if at all. When I back off the throttle it slowly creeps down from max. Assuming a small leak in the line? Is this fairly common and/or and easy fix? Working as designed? I'm not 100% sure, but I believe it's the stock gauge that comes with the Hahn kit.
2. Oil leak I'm not sure yet where it's coming from but it's on/around the blower. In searching I've seen many a post blaming oil leaks on the low mount of the turbo with the stock Hahn header. To make matters worse, I not only overfilled the oil just a bit (due to some questionable assistance from my spotter), but I also have the a$$ end of the bike jacked up since I was bottoming out. I would like to bring up the front to match, but I don't see that I have any travel on the triple tree and I believe the forks have been internally lowered. Kind of stuck on this one. Any idea where to look for the oil coming out if this is indeed the problem?
3. My giant K&N filter keeps falling off the turbo every few days. I pull into my garage, set the bike on the side stand, and it just falls on the floor. I've got the clamp cranked as much as possible, but just keep dropping off. I'm assuming it's the right filter, but it's got some sort of adapter cup on it to change the size so it fits the inlet. Does this sound right?
As always, thanks for the help guys!
Gonz
Gonz
