Oil Leak Problem
Busa204
Ok had my oil changed a couple of months back & ever since my underside has been getting what seemed to be oil on it. It actually got on the bottom parts of the fairings & turned them slightly yellow. Now I took it back to the place that did the oil change & said I had a leak somewhere. They checked the bike & said nothing is wrong with it & that must be coming from the road. Well I just looked at the underneath again & I noticed on the screw you take out to change the oil, it had a little bit of oil on it...
Now it's not a major leak by any means, it just seems that the vibrations make it slightly come out from that spot. Now is there suppose to be some sort of gasket there to stop that?
Check the filter first. If not on jsut right it could be running down. Put some white paper under the bike and see if you can catch where it is coming from. Could also be the crush washer. you should use a new one every coup;e of times
Be careful Hope to god that it did not get over tight and stripped.
I sent ya a pm NE......Also I checked to make sure the oil lvl isnt droping everytime im out on the bike & it doesnt seem to be.....Thnx for the help NE...
I sent you a reply. You are not loosing much so just run. However you should check if your plug is even tight enough. BE VERY VERY CAREFUL hand tighten with a socket not the whole ratchet. Go back to the guys who changed it unless you changed it?? If you did check the Plug and the washer.
