Oil leak
cerebusa
Starter clutch was replaced about 2k mi. ago.Noticed oil under fairing,looks to be the place.Already tightened bolts.It is not coming from oil sender,or clutch cover.Question is ?? When I remove the cover is there anything thats going to come flying out?Or can I just remove cover,new gasket, then replace?..Also clutch fluid is dark,where do I bleed this out at?I know its on the left side,but I see no bleeder valve there. thanks guys,,,99 busa w/22063 mi.
your welcome
