Orgsters...Pan pulled..working on getting a pan. But can we discuss the merits/demerits of some of the ideas submitted...
1. My neighbor, who is a Harley guy had his oil pan welded, plugged, tapped, and ba-da-bing...good as new
2. Is heli-coiling it even better than new? Some racers use it as being better than the regular oem if I understood the post correctly.
3. Go to a full race pan of 2 inches...but wouldn't that mean having that much less oil to circulate? Current pan measured looks close to 4 inches.
4. Use an aluminum plug and wire it once closed so you never worry about stripping the darn thing again (this sounded like great advice).
5. Tap it out to next size and get the corresponding bolt size...but when you look at the hole from the inside of the pan it doesn't look like it would be possible.
6. Haven't been able to see what the Stealership wants for a brand new pan but I'm guessing 3 hundred.
Mechanics can you address the merits/demerits of these items...okay at least some of them...I hate to just chuck a good pan that has a bad hole2hip
