I need help, do not understand where to post this topic...
I have a hayabusa engine in a morris mini. Last year i had trubble with the cooling of the oil. This year i change to a much bigger oil cooler, with larger oil lines, and moved the cooler in front using 2x 3m 10-an hose. I belive this is the reason to my problem, but i need as much cooling as i can get.
I also innstalled an APE high oil pressure gear, but my oil pressure is still very low (>1 bar with hot engine, 5 bar when reving up)
What to do now?
I can move cooler, so i can use shorter hoses...
I can use a smaler cooler...
Thinner hoses...
Are there somthing els to do?
Please help, tell me what you would have done...
What to do now?
Thinner hoses...
