mike1180
Banned
I have taken my oil pressure, as described in the manual.
The bike was nice and hot(140 degrees) and the pressure was at 200kPa (28 psi) at 3000 rpm, which is right at the lower level of normal.
Is that a normal value?
I would have thought that it would be in the middle or so of the Quoted range of 28 to 71 psi.
That seems like a large range for me to be sitting right at the bottom.
I also tried it with 2 different oil pressure gauges, and it was the same.
What are you guys getting as oil pressure readings at 3000 rpm?
Thanks!
Mike A
Thanks!
Mike A
