ditchdr
I got a 12x8 enclosed trailer to haul the lawn stuff in on the way. I plan out out fitting it with a small air compressor, a roof mount a/c, and some lights on the inside as well as 4 out lets to run power tools if needed.
Would like to know what size genny I would need for this
A/C 14.6 amps 110v
Air compressor 15 amps 120 volts
2 shop lights 28 watts each on 110 volts.
I also want to be able to run a grinder or elec impact gun while the a/c or air compressor is running. There will be a small work bench built into the first 2 feet fo the trailer that will have a gcfi outlet on each end, as well as 2 water tight gcfi outlets on the out side.
Pretty much be able ot use it as a mobile work shop for the mower or what ever else might break while doing lawn work.
A/C 14.6 amps 110v
