B-12
Was on the dyno today , and here my result.
2001 Busa with MPS fast FI box. 32jet
Could only do 3 runs cause i had only one small bottle.
AFR 13.6 is near to the limit i think and i wont use a bigger jet.
Maybe the result is a bit low because of the Shinko ,which had a lot of spinn. Tuner makes a lot of superbikes and said racetires and soft tires as shinko are not good for dyno. After the run it looked like melted ,and there may be 6-8 more hidden horses ,with better grip.
Just Motor was 159 RWP , but seems i lost 8 HP because of the 4 short stacks. With stock stacks i had 167-169
Sprayed at 6500 rpm with 800 psi and only 12 Oz bottle
Printer was out of ink so the sheet is a little red.
In two weeks i will dyno it again with PiPo and two bottles to keep pressure constant .
