OOPS!  lost a couple o bolts
mjn
Hillbilly Deluxe
I just swore off doing ANYTHING with my bike after alceehaul consumshun....
I decided to put on the hump, which required the removal of the grab bar.
Didn't realize that 2 of the 4 bolts had caged nuts...the other 2 did not. Dayum things fell inside my undertail. $hit!
I figure they'll fall out eventually.
You may find it easier after the alcohol wears off to remove the tail section. Loose bolts rolling around on the bike aren't generally a good thing.
I messed around with a magnet with no luck.
Hell, there is always a loose nut hanging on to the bars,
a couple more won't hurt.....I think they are gone tho.
you should cut out the small section, like i did, so ur grab bar stays on all the time....hump or second seat, no pics, but im sure im not the only one on the board who took a dremel to the hump!?!?
yea, ya know, I figured that was what everyone was doing. Just the thought of grinding on my toy makes me cringe!
Same reason I haven't put sliders on it yet...
