arthur39
got a linear style quick shifter, was wondering if a direct run to the pc3 with just the fuel cut off would be ok? I am considering the ignition module so I can get fuel and ignition cut off together. I would think it is a fuel hard cut from the power commander, 80ms or so (wasn't sure if this would cause a lean condition without ignition cut off)
Im wondering if just the fuel cut will work, I have flashed the ecu with a fuel hard cut only and have bounced off the rev limiter on a few occasions full boost, with no adverse affects.
Lemme know if you think I should invest in a ignition module or just run the fuel cut. tanx
