StenBusa
Hi all,
Tried to search this but could't find answers to some of my question, may not have been using the right key words.
My bike has been in storage for a couple of years, it was not my intension for it to be so long but it was. I believe I did everything correct; changed and put fresh oil, filled tank and added stabil fuel treatment, and got the wheels of the ground. What I'm concerned about is the length of time.
What's the correct procedure to wake her up?
I remember reading to remove the plugs and drop in a tea spoon of oil, turn the motor over a few times (plugs still out) to lube the cylinders and then replace the plugs. Should I change oil before or after this step?
I also plan on changing the battery as it's the original one and it's an 07. The gas tank will come off to drain the old gas and replaced for new.
Of course I plan on going over the whole bike brakes, clutch, etc., but my focus now is correctly doing the engine.
Thanks in advance..........
