A little while back I bought this Suzuki rear Bike stand, Only used it a couple times and loved it.
After stretching Misty 6 1/2" I was unable to use the stand because the stand hit the extension long before the cradles met up with the spools. Started checking into different stands that would work, Then I walked out in the garage and decided it was going up on the stand, Figured all I had to do was raise the rearend up high enough for the stand to slide under, and ended up making a permanant solution. Didnt cost me a thing.
Roll the bike up on the ramp, Have a couple blocks same height for the kickstand and wallah.
Figured maybe someone else might run into this problem some day and heres away around buying a new stand.
