PAIR Solenoid bracket removal?
Mythos
I already have mine out and have installed block off plates. Just wondering... how/from where did you reach the screws that secure the solenoid bracket to the frame? as you can see, I simply reached in where the radiator was since I had it off anyway. Also had to pull off that wind cover wing (my name for it) that appears to be meant to isolated from the airbox area.
The solenoid bracket is located right in front of the leading edge of the head cover on the underside of the frame.
The "Windcover Wing."
Here is how I got on them.....just wondering if there would be a simpler way that does not entail removing the radiator??
I was able to use a 10mm gear wrench on an angle that was good enough to get the bolt loose from under the tank. just had to pull the 2nd and 3rd coil plug pack and had no problems minus a little frustration only because I got big fingers haha but didn't have any issues doing it
