Why wouldn't it work just as well on the pair valve mod/removal to just remove the valve, put longer pieces of hose on the bottom of the tubes where they use to connect to the valve, and just connect them to each other, then you have isolated the tubes without even having to remove them.. Install 2 vacuum caps on and your done.. Instead of buying a kit and removing all the tubes..
