pair valve
rickytan1000
I just remove the pair valve from my busa,runs a lot better but now f1 indicator light is turning on
can some please let me know what to do to turn it off.
You may have dislodged a connector or wire. There are no electrical connections to the pair system.
Check all the places you worked around.
Putting the ECU into test mode with the shorting link (link and codes shown in this site someware) may help track down whats gone bad.
Cheers
Ross
Cheers
Ross
+1
A quick thing to check, don’t laugh, that has happened is bumping the run/stop switch to stop.
It sounds silly and is a little embarrassing but I recall someone mentioning it on this site.
If it’s the case at least it’s a free fix.
Cheers
Ross
