Trying to keep up with you guys on modifications on the hayabusa has led to a strange thing occurring. On September 26th, I had a (Stebel Nautilus Compact Motorcycle Air Horn) and Hid kit (Wattage : 35W Bulb Type : H7 Bulb Color : 5000K & Wattage : 35W Bulb Type : H9 Bulb Color : 5000K, by DDM Tuning) installed by a local motorcycle shop. When I drive down the road or while the bike is just sitting and it does not happen everytime, if I hit the passing light switch on the bike (I could hit it maybe like 10 times or so) it can make the internal dash lights cycle. When I mean cycle, it looks as if I am turning the key on the bike for the first time, type of cycle. All the other lights are fine and it does not make the engine cut out or anything. What could be the problem? Anyone heard of this? I did take it back to the local motorcycle shop and they could not find anything thing wrong at all. I even have a different battery installed thinking maybe that is the problem and it did not solve issue. I cannot be sure if the this did not happen before the install of these items when the bike was stock. Anyone have any ideas? Please chime in. Again...it is not everytime I hit the passing switch.....you might be able to hit the passing switch like 20 times and during one of the presses it might do this. When this dash light recycles, the clock even resets. Please help!!!
P.S. 2009 Hayabusa
P.S. 2009 Hayabusa
