Jza
Just fitted my new shorty Pazzo levers to my K8.
Problem is - if i turn full lock and have the levers set to the furthest "out" position the bottom of the brake lever (near the knuckle) hits the instrument pod (not a big bang but its defo touching - i can see the mark its leaving and feel the brake move).
If i set the brake lever to 3 which is where i want it, it still gently touches.
Have tried moving the whole lever unit and cylinder to all extremes, and moved the lever up and down as far as possible, there is still an issue.
Anyone had the same problem and if so is there a workaround other than filing the lever down?
Cant believe ive paid £129 for something that doesn't fit the bike !!!!
Jza
Jza
