PC III USB Question....
Over_Easy
GEO-STABILIZATION EXPERT
Can the PC III USB be turned OFF while installed and if so will it revert back to the stock fuel map automatically?
Nope you have to put a zero map in it to revert to stock, or take it off. The DJ website has zero maps though, and stock maps that are supposed to enhance a bone stock bike. And the maps are very easy to change if you have a lap top or pc you can take out to your bike ;)
yep .. what he said
sort of a left handed way to do it would be to put the zero map in, then use the rich/lean buttons ... From what I have read, the system will revert to the base map when the bike is turned off and on.. not sure if it is true or not, never tried the buttons..
quit reading
