Hi,bike is stock (2000)except for Force Sumo exhaust,PC2,small airbox mod,&removal of PAR Valve/block off plates,also custom map,bike runs OK,but I was considering
a change to the newer PC3 USB...any advice on this change
imo.. keep the PCII. the only advantage is the PCIII does incriminates of 250rpms instead of 500 rpms. plus the PCII u can do fuel AND Ignition, where as the PCIII's u can only do Fuel, and if uw anna do ignition,, u gotta drop $300 for that "add-on".
