There's already a large quantity of babble regarding the PCII on this board, but I felt this one needed to be heard. I was not able to run my bike with the PCII. For those of you who are not familiar with my bike, it's a '99 w/Akra full exhaust, no PAIR valve, and a BMC filter. When I added the PCII with the proper .006 map, the bike would not run from 4k rpm up. I had my dealer replace my Crank Position Sensor (CPS), did nothing. I gave up for a while since the bike ran fine w/out the PCII. I was however, determined to get it to work, and last night I committed to the time. With the help of site member Daveo, and his scope, and a couple 'Busas to compare to, we got it working. When we scoped the voltage output of the CPS on a stock 'Busa vs. mine, mine was putting out almost double the voltage. We thought about trying to move the CPS up or down to change the voltage, but Dave (The Man) figured out a much less time consuming fix. We used a variable resistance tool of his to determine how much resistance was neccesary to bring down my output voltage. We put the resistance tester across the Blue and Green wires at the connector for the CPS, and when we got to 600 ohms resistance, the voltage matched that of the stock 'Busa. We then used a 600 ohm resistor across the Green/Blue wires, and the bike now runs fine. Dave is a genius!!!!! Cudos to you Dave.
Oh, by the way, the bike is much more powerful now, to the point that while on the highway on my way home, I found myself, more than once, trying to shift into 7th gear. This was because the bike had so much more power in 6th that I thought I was only in 5th.
Sorry for the techy talk, but for those of you dealing with similar PCII/'Busa problems, I thought this might help you get it right. I would still recommend the PCII for it's unparelled adjustability. Did I forget to mention that Dynojet replaced my PCII without any hesitation, before we knew if it was the PCII causing the problem. They are great to deal with!!!
[This message has been edited by RPM (edited 09 August 2000).]
