PCIII killing my bike ????
99busaq8
hey guys..
well i installed the PCIII and quickshifter with LCD to my bike..
the mechanic who installed told me to leave them unplugged so as not to mess up the bike untill i get it dyno'd.. I took the advice..
when I took my bike to get the fuel pump replaced the other mechanic hooked it up and said ( no nothing will happen to your bike and u can drive it without dyno right now )) i didnt trust that..
annnnyhooow.... the past three times i went out on my bike.. when i start it up the LCD says ( NO POWERCOMMANDER ) on the screen and the bike wont start.. its sounds like it will start but no turn over in the engine.. so i shut the bike shut then on then off then on then off then on.. the message goes away.. and WALLA its starts @@ WTF?
could there be a problem with the PCIII? or is it something else that isnt letting my back start?
has anyone had a PCIII on the bike with no dyno and suffered simialer probs?
thnx in advance !
it will only when the message goes away ! its wierd !!
i have to shut the key off and on.. then wait 10 minutes or so.. then it starts..
I would suspect that the problem could be related to your fuel pump or other work that you had done. If you haven't already, try running the bike with and without the PC hooked up. It shouldn't hurt anything having it hooked up so give that a try.
i did for about 2 weeks without the PCIII connected nothing happened.. but since it was connected that started !!!
i know ur probably saying '' THEN WHY DONT U UNCONNECT IT ALLREADY ! ''
well i wanna know why the PCIII would do that !
I like to know how everything works.. and WHY WHY WHY everything else happens...:whistle:
Does the pc3 have a map loaded in it? might throw it up on your pc WITH the bike running, check your fuel tabels, AND MORE importantly your TPS(throttle position sensor) is ZERO'D out! Also do you have The hub switch with the ignition box? Might be something wrong there too, try taking it out of the equation and see if problems go away? IF ALL ELSE FAILS, call dynojet, they have a GREAT TECH SUPPORT!:beerchug:
I bet you didn't load a map onto the PC3. You have to load the program on your computer and then download the map using the supplied usb cable and the 9v battery connector. After you download a map to your computer, then select "send map" and click on the map you downloaded. The software will then load your PC3 with the tune and your set.
WHAT?????
map or no map the bike will run.
you can install a PC3 with or without and still ride the bike.
try to reset the pc3 first.
ok i havent loaded a map yet.. cuz i was waiting for the specialist here to do it..
if someone could teach me how to do the settings i would do it my self... HELP :p
how do i reset the PCIII !!
i was looking for a reset button but i couldnt find it...
**** why didnt i read the manual @@ i allways do.. but didnt this time.. :poke:
let me check all this out tonight.. going to the mechanic in an hour.. going to bring my PC.. see what i can do.. hope it works out.. the weather is just getting perfect.. ughhhhhhhhhh
GEEEEZ !!!!!!!!!!!!!!
iwent to the shop.. i conneceted to PCIII to my laptop.. didnt connect.. couldnt find out why.. checked the cables.. looked for trouble shoot still couldnt find an answer.. !
any how... My clutch was so loose felt like an old rubber band.. it turned out my clutch fluid was dry to the drop ::11
filled it up.. seems like its ok now.. but i dissconnected the PCIII till i find a proffessional..
thnx for the reply's.. hopefully i can go 1 day out without a new problem showing up.. god dayem !
