Busa Sweden
I have a problem to solve.
I have a 03 stock busa and is about to get some mods running. I have been told that there are ignition restrictions on the first three gears between 1500-5000rpm with -5 degress and 6th gear topend due to topspeed restriction. If i get a ATRE I can not make changes to the fuel settings but I can set what gear to "re-ignite". My PCIIIr can change the timing but not by gear, only by rpm, so if I change the timing in the 1500-5000rpm area with +5 degrees it will also add 5 degrees in all the other gears where I not have the timing restriction/problem.
My conclusion is that I must have a ATRE to fool the ECU in thinking that my bike is in 5th gear all the time (this is the TRE that don't change the neutral map) and then I can make any fuel or timing change with my PCIIIr.
Have I brainstormed to much?
Joakim
Joakim
