pcv quick shifter question
Ikillbugsfast
the bikeis a 2011.what would I need to order. I all ready have the pcv.and what is a Quick Shifter Expansion Module (Q.E.M.) what does this thing do or do I even need it or do I need to order the pcv Quick Shifter with it
It cuts the ign for a predetermined amount of time...you up / down shift and it assists a clutchless shift...with a bang because the fuel keeps pumping. I believe that it only works one way as in up shift or down depending on your shift lever set up
That is correct. The shifter rid sensor only works 1 way.
Unless something changed with the introduction of the PCv, the quick shifter cuts the fuel instead if the ignition. No "pop" on them.
